Dabar yra Sek Geg 31, 2020 23:42
StandartinėParašytas: Ket Rgs 21, 2017 19:56
Užsiregistravo: Ket Rgs 01, 2016 18:30
Pranešimai: 11
Sveiki, gal kas padesite. Meta kelias klaidas ir niekaip galu nerandu. Ryte vaziuojant ir truputi spustelejus gaza ismeta
DF301 - Air inlet circuit
- Leak detected
- Intermittent
Bet trauka nedingsta, tik check lempute dega.
O isokus i autostrada ir spaudziant gaza ismeta sitas klaidas ir dingsta trauka.
DF199 - Turbocharging pressure sensor circuit
- Short circuit to +30
- Intermittent
- Turbocharging pressure regulation circuit; Pressure too high
- Intermittent
Pakeiciau Map sensoriu, bet niekas nepasikeite. Gal turite ideju? Auto Renault Espace IV 2.2dci 110kw
StandartinėParašytas: Ket Rgs 21, 2017 21:59
Pranešimai: 1834
Anewil rašė:
- Leak detected
- Intermittent
- Intermittent
- Intermittent
Check that the control rod of the turbocharger is not jammed:
– Run test 6 Fixed geometry turbocharger vacuum control, for a fixed geometry turbocharger.
– Run test 7: Variable geometry turbocharger vacuum control, for a variable geometry turbocharger.
