Espace IV 2,2dci...Dingsta trauka https://www.renaultclub.lt/forum/viewtopic.php?f=50&t=46507 |
Autorius: | Anewil [ Ket Rgs 21, 2017 19:56 ] |
Pranešimo tema: | Espace IV 2,2dci...Dingsta trauka |
Sveiki, gal kas padesite. Meta kelias klaidas ir niekaip galu nerandu. Ryte vaziuojant ir truputi spustelejus gaza ismeta DF301 - Air inlet circuit - Leak detected - Intermittent Bet trauka nedingsta, tik check lempute dega. O isokus i autostrada ir spaudziant gaza ismeta sitas klaidas ir dingsta trauka. DF199 - Turbocharging pressure sensor circuit - Short circuit to +30 - Intermittent DF301 - Air inlet circuit - Turbocharging pressure regulation circuit; Pressure too high - Intermittent Pakeiciau Map sensoriu, bet niekas nepasikeite. Gal turite ideju? Auto Renault Espace IV 2.2dci 110kw |
Autorius: | jawnas [ Ket Rgs 21, 2017 21:59 ] |
Pranešimo tema: | Re: Espace IV 2,2dci...Dingsta trauka |
Anewil rašė: Sveiki, gal kas padesite. Meta kelias klaidas ir niekaip galu nerandu. Ryte vaziuojant ir truputi spustelejus gaza ismeta DF301 - Air inlet circuit - Leak detected - Intermittent Bet trauka nedingsta, tik check lempute dega. O isokus i autostrada ir spaudziant gaza ismeta sitas klaidas ir dingsta trauka. DF199 - Turbocharging pressure sensor circuit - Short circuit to +30 - Intermittent DF301 - Air inlet circuit - Turbocharging pressure regulation circuit; Pressure too high - Intermittent Pakeiciau Map sensoriu, bet niekas nepasikeite. Gal turite ideju? Auto Renault Espace IV 2.2dci 110kw Check that the control rod of the turbocharger is not jammed: – Run test 6 Fixed geometry turbocharger vacuum control, for a fixed geometry turbocharger. – Run test 7: Variable geometry turbocharger vacuum control, for a variable geometry turbocharger. |
