1Kestas rašė:
Sveiki.kalbejaus su meistru rado sitas problemas DF772,DF098 Fuel temperature shown -50 salcio.butu gerai issifruot tuos kodus.aciu
DF098
PRESENT
FUEL TEMPERATURE SENSOR CIRCUIT
CO.1: Open circuit or short circuit to +12 volts
CC.0: Short circuit to earth
NOTES None.
Check the connection and condition of the 2-track connector of the fuel temperature sensor.
Repair if necessary.
Check the connection and condition of the computer 48-track brown connector B.
Measure the resistance at the fuel temperature sensor terminals.
Replace the fuel temperature sensor if the resistance is not approximately 2.2 kΩ at 25˚C.
Check the insulation, continuity and the absence of interference resistance on the following connections:
Sensor connector track 1 track G2 computer connector B
Sensor connector track 2 track G3 computer connector B
DF772 DDCR ECU (kuris eina su K9K 722, 728, 729 varikliais) nera ir negali buti taip pat tos klaidos negali buti ir DCM 1.2 ECU bloke (kuris eina su K9K 718, 724, 740, 750, 752, 766, 768, 800, 802, 812 varikliais) analogiska situacija ir su Siemens SID301 ir 304 ECU (kurie ejo su K9K732, K9K734, K9K764, K9K772 K9K804, K9K806 varikliais)
darau isvada kad diagnostika rodo pieno riebuma....... nebent DF772 klaida kokiam kitam bloke bet tikrai 1.5 dci ECU jos negali buti.....
na ka perziurejau ir visus kitus blokus nei ABS, ESP, UCH, UPS, parkavimosi, rankinio stabdzio, xenonu, prietaisu skydelio, airbagu blokuose DF772 klaidos negali buti sveikinu jei uz diagnostika mokejai ji nieko verta yranga nedraugaujanti su Renault
