Dabar yra Pir Bal 29, 2024 08:32
StandartinėParašytas: Sek Spa 01, 2023 19:34
Užsiregistravo: Sek Spa 01, 2023 19:30
Sveiki visi, rašau į šį foruma vien del to nes turiu labai daug klausimu apie savo norimas modifikacijas savai lagunai. Aišku iš anksto atsiprašau, kad klausimai bus anglų kalba nes lietuvių kalboj sunkiai sekasi man orientuotis :oops: :oops:
All questions to ask about Renault Laguna Mk1 PH2; 1.6 16v K4M 70x; Sirius32 ECU;
Exterior/interior:
* Where to get a full suspension kit (Front and rear) for track/street use?
* Is there a kit to change the rear drum breaks to disc breaks?
* Does a pre-made widebody kit exsist?
* Is it still possible to get new interior pieces in the baltic states?
* Is it possible to get angel eyes fitted for the stock headlight housings?
* Where to get wheel hubs to change the bolt pattern from 4x100 to 5x100/110/112 and etc.?
Engine:
* How much HP/kW can the K4M engine withstand with stock internals?
* Where to get ITB's (if they are still avalible) for the K4M engine?
* Where to get equal length hedders (if they are still avalible)?
* Does a equal length hedder with a turbo addon exist (for future forced induction)?
* Best injectors, fuel pump and spark plugs to get more HP/kW for remaping efficiency?
* Whats the best clutch kit for track and street use?
* Best camshaft for street and track use and where to get one?
* Is there a map tunner in the baltic states?
* Does head porting, flowing and polishing help with power production for this engine?
* What aftermarket internals are the best to strengthen the motor to withstand good amounts of HP/kW?
* Where to get a performance intake manifold (if they are still avalible)?
* Where to get a full performance exhaust (if they are still avalible)?
Gearbox:
* Should you change the gearbox oil, if yes in what intervals should it be changed (X amount of km)?
* Is there a 6 speed gearbox that fits my mk1 ph2 laguna whithout any adapter plates, and if there is whats the best one to handle a good amount of kW/HP (cannot curently specify how much kW/HP is "a good amount" because curently dont know how much power can a stock K4M 70x engine and 5 speed gearbox handle), and is good on top speed?
* Does a short shifter kit exist?
ECU:
* Does the stock sirius32 ecu accept flashing and or remapping, or should i get a piggy back ECU, or a standalone ECU
* Whats the best, if needed, standalone or piggy back ecu with knock protection thats compatible with the car?
* Do you need to make a custom wire loom or is there one pre-made, if needed, for a standalone or a piggy back ecu?
Random questions:
* Whats better for power production when remaping: cold air intake or ITB's?
* For future forced induction whats better: a turbo or a supercharger?
Renault Laguna I ph2 1.6 16v 79kW
