| Audiobahn https://www.renaultclub.lt/forum/viewtopic.php?f=13&t=20080 |
| Autorius: | Velsat1s [ Pir Rgp 18, 2008 20:25 ] |
| Pranešimo tema: | Audiobahn |
Sveiki, radau skelbimuka, ir nusprendziau paklausyt profesonalu nomuones apie ji. Taigi, siek tiek info. Audiobahn bosas su deze: Sensitivity: 94 dB RMS Power Range : 650 Watts Peak Power Handling: 1300 Watts Impedance: 4 Ohm Low Frequency response: 22 Hz High Frequency Response: 7000 Hz Diameter: 15 Inch Audiobahn stiprintuvas: 200 X 2 at 4 Ohms Stereo 400 x 2 at 2 Ohms Stereo 800 x 1 at 4 Ohms Mono Dimensions: 1-7/8" H x 9-7/8" W x 11-7/8" D COMMON FEATURES Class A/B MOSFET Circuitry PWM MOSFET Power Supply Semi-double Glass Epoxy Circuit Board THD: 0.02% S/N Ratio: 100dB Frequency Response: 10Hz - 40KHz (+/- 1dB) Variable 18dB Hi-pass Crossover: 50Hz - 750Hz Variable 18dB Low-pass Crossover: 50Hz To 120Hz Bass boost on/off Subsonic Filter: 20Hz to 50Hz RCA Throughput Connections 3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan Cobalt Blue Illumination High gloss Chrome Plated Finish Nickel Plated Block Terminals Air Induction Fan Cooled RCA and Speaker Level Inputs Kaina: 600lt. Man dideliu bass'u nereikia, tik reikia atpirk nekokybiska originalios aparaturos grojima. Ar apsimoka? |
| Autorius: | Ell-Bee [ Pir Rgp 18, 2008 21:54 ] |
| Pranešimo tema: | Re: Audiobahn |
kazkodel perdaug pigiai.... o siaip jai tau dideliu bassu nereikia tai tau sitas kompletas netinka, 15 coliu diametras ir 650w rms tikrai skirta dideliam kiekiuj zemu dazniu |
| Autorius: | Velsat1s [ Ant Rgp 19, 2008 10:18 ] |
Pigiai nes jau pirkciau is antr ranku. O jei galingas sub'as ant mazesnio garso grziai groja. |
| Autorius: | Ell-Bee [ Ant Rgp 19, 2008 10:45 ] |
jai nori kad graziai grotu tai nepirk 15 coliu subo pirk 8 arba 12 geriau du po 8 |
| Autorius: | zaliuks [ Ant Rgp 19, 2008 11:32 ] |
is RF gali ka pasiziuret .tikslus ir minkstas bosas. |
| Autorius: | Velsat1s [ Tre Rgp 20, 2008 19:17 ] |
Žinau, kad ne į tema, bt kad nekurti naujos... Nužiūrėjau Elektromarkt parduotuvėje BassX komplektą. Stiprintuvas (1100w), subas (300W rms/600W max) ir 4 kolonėlės(viena ~150w, bet 2 apvalios ir 2 elipses). Kaip firma? Ar apsimoka už 600 imt? Ar gražiai skambės? |
| Autorius: | Ell-Bee [ Tre Rgp 20, 2008 21:13 ] |
Nemalk sh su tokiai dalykais jai nori skambesio ir uz tokia kaina velsatyje skambesio neisgausi.. tau reikia geru komponentu i prieki kaina 300-500Lt duru paruosimo(vibro izoliacijos ir podiumu durims kaina manau kokie 500-1000Lt uz abi duris) gero stiprintuvo kaina 500-1000Lt laidu kaina nuo 200Lt ir boso na jai imti pigesni apie 300-400Lt. Jai nori tikrai gero skambesio aiku reikes gero grotuvo, cia sakyciau minimalus biudzetas geram skambesiuj velsatyje. Visa kita bus tik triuksmas automobilyje. |
| Autorius: | Velsat1s [ Ket Rgp 21, 2008 15:53 ] |
Oj, (pyp)... Geriau A6 buciau pirkes... |
| Autorius: | shtrafas [ Pen Rgp 22, 2008 09:49 ] |
Velsat1s rašė: Oj, (pyp)... Geriau A6 buciau pirkes... ne masinoje esme zmogau aisku kaip cia aiskino kolega apie sumas tai galima ir pigiau darytis..nemazai pigiau, pvz apsieinant be izoliacijos..juk nevaziuosi i parodas |
| Autorius: | Ell-Bee [ Pen Rgp 22, 2008 15:56 ] |
na zmogus norejo gero skambesio todel pasiuliau detis garso vibro izoliacija |
| Autorius: | Velsat1s [ Šeš Rgp 23, 2008 21:08 ] |
Žiūrėkit, ką sumasčiau. Imsiu Pioneer Avic-x1 magą, Pioneer Free-Air į palangę, ir kokį Pioneer stiprintuvą. Kaip jums šis derinys? |
| Autorius: | zaliuks [ Šeš Rgp 23, 2008 23:51 ] |
modelius tikslius su nuorodom ikelk tada galesim gal ka patart. |
| Autorius: | Spydas [ Sek Rgp 24, 2008 00:06 ] |
free-air į VelSačio palangę?.. |
| Autorius: | Velsat1s [ Sek Rgp 24, 2008 12:25 ] |
Nu tjgi free-air apskaiciuotas det i palnges. Ir nepasakyciau, kad ta bagažinė taip jau labai skiriasi nuo sedno... Magelis: http://www.alphacaraudio.co.uk/images/O ... C-X1BT.jpg Subas: http://www.alphacaraudio.co.uk/images/O ... -W307F.jpg Stiprintuva net nežinau kokį imt... kokį ~ 800w gal planuočiau... |
| Autorius: | Ell-Bee [ Sek Rgp 24, 2008 15:22 ] |
vistiek neissisuksi be komponentu i prieki. |
| Autorius: | Spydas [ Sek Rgp 24, 2008 20:35 ] |
Velsat1s rašė: Nu tjgi free-air apskaiciuotas det i palnges. Ir nepasakyciau, kad ta bagažinė taip jau labai skiriasi nuo sedno... sedane palangė nejudama, rėmas metalinis. Galima prie metalo sriegt kokio nori storio plokštę, dėt bitumą, sandarint kaip nori - tada iš free-air`o paimsi viską. Tokios jau sąlygos kad užgrotų - tvirtumas ir sandarumas. O hatch`e su lentynos bei jos tvirtinimo tvirtumu ir bagažinės sandarumu vieni, kaip čia pasakius - sąlygiškumai ir kompromisai. Va toks su sąlygom ir kompromisais ir gausis paskui bosas. O paskui nuo savininko priklausys - ar pasakys "ai, nu norm", ar pasakys "Š tas free-airas", nors didele dalim ne free-airas, o netikęs jo realizavimas kaltas. Daryk aišku kaip išmanai, tik prieš tai gerai pagalvok, bo jei nepatiks - iš naujo perdarinėt teks |
| Autorius: | Velsat1s [ Pir Rgp 25, 2008 20:03 ] |
Aš žadėjau iš fanieros daryti kitą palangę, ir su stiklo pluostu padaryt kažką panašaus i tai: http://www.integrityplusautobody.com/me ... eb$201.jpg tik ne ant dėžės, o ant palangės.. |
| Autorius: | Spydas [ Ant Rgp 26, 2008 11:55 ] |
Velsat1s rašė: Aš žadėjau iš fanieros daryti kitą palangę, ir su stiklo pluostu padaryt kažką panašaus i tai: http://www.integrityplusautobody.com/me ... eb$201.jpg tik ne ant dėžės, o ant palangės.. ESu matęs žurnaluose |
| Autorius: | Velsat1s [ Ant Rgp 26, 2008 17:34 ] |
Nu gal ir gera mintis
